Incoming supply cable and 16mm/25mm tails questions
Hi, I've rewired a property, 100A main fuse, 2 electric showers plus everything else so maximum demand is potentially over 100A in theory. I added a main isolator and used 25mm tails to the CU. The distributors tails look slightly smaller so I'm assuming 16mm unless the sheath is thinner.
Does everyone report if there are 16mm tails on a 100A main fuse? Why did the distributor not put 25mm tails in when they put a 100A fuse in? Does anyone know what size the conductors of the actual incoming cable are? If less that 16mm does that mean digging the street / house up to replace it with 25mm?
Thanks!
  • Jolly good. You complied with the EAWA by ‘isolating’ first. If doing a report rather than a cert for installation, just put ‘Lim’ in the ‘mains fuse rating’ box - since we are not allowed to touch it officially how can we know without pulling it to see it? That box should be removed from the form.
