Q1.R.C.D. tripped by disco decks.
I am checking a Citronic item. It is a double deck disco console called a Stereo Popular. It is unpowered and needs a separate audio amplifier. It causes a 30mA R.C.D. to trip off. This is an irregular problem. Sometimes the turntables will rotate normally, one showing a change of speed sometimes which is noticeable when a record is playing. The only mains in is to a small Holden & Fischer toroidal transformer. No internal fuses blow, and all insulation resistance tests show infinity resistance. There is a ground/earth connection from the E.L.V. side of the power supply board that has two 1,000 micro Farad electrolytic capacitors. I wonder if one is breaking down and causing a leakage to earth? But that is only on the E.L.V. 15 Volt side. Any ideas please?
Edit. Add. The unit dates back to the 90s I believe, but is of very good quality. It plays vinyl records and has two permanent magnet D.C. turntable motors with speed controls for mixing.
I can't understand how a fault on the 15 Volt side of the power supply circuit board can cause an R.C.D. trip.
It looks like this, although the image is of a mono version.
www.ebay.co.uk/.../403346023714
  • I presume you do not really mean 'unpowered'  do you ?
    So which RCD trips - the one for the deck motors or the one for the audio ? The audio cable braid/screens being at mains earth potential is perfectly normal & reasonable - and I;d expect it to be more or less the same if the amp and the deck are connected to each other or not. So with that audio lead unplugged at each end in turn as a means to get onto the audio cable screen, how many volts between amp input earthy side, and deck output, earthy side of connector. (turn the amp volume down so that you do not blow anything with a large 50Hz pick-up during this test.)
    And then if not the same, which is furthest volts wise from supply CPC ?
    The electrolytic caps do not worry me, and unless bulging, leaking or measuring voltages above their label rating, will be fine as they are  -  a center grounded DC supply is a normal thing to find on an audio system - it allows the speakers to both blow and suck equally when the drums go bang, but no text book will describe it thus. 'DC coupled symmetrical push-pull'' is more likely...
    You can have a single sided DC supply but then you need to AC couple the outputs, limiting the LF response and offending the purists.
    Caps in the mains side of things from L-E or N-E should be treated as far more suspicious,  (or surge arrestors in the same positions )especially if more than a few tens of nF
    I do not think you have found it yet, in effect you have a symptom, not an explanation.
  • Thanks Mike. The "unpowered" refers to the decks not having an audio amplifier. An external one is needed. "Powered" decks have a built in audio power amplifier.
    The amplifier runs through a 100mA R.C.D. and the record playing double decks run through a 30mA R.C.D.
    I will examine things more thoroughly.
  • The Voltage between the earthy screened audio Amplifier input and the earthy screened audio output of the decks is about 1.27 Volts A.C. when using two separate supply  circuits.
  • Just wondering aloud ... might one of the items of equipment have the chassis connected to N instead of PE - that was common in the days of CRT TVs but as far as I know wasn't usual for more general audio equipment, but you never know...
  • And that RCD setup is an odd choice - why not both via the same 30mA RCD ? Is there a known problem with high leakage from the amp I wonder.
    Note that some older  American audio amp designs do get a bit confused about earth and neutral, as they were a long time getting 3 pin plugs, and there have been a few nasty accidents with 2 pin adapters the wrong way round making microphones and guitars live. Let us hope it is not that - but always beware the black and white mains lead - white is PME neutral ;-) but I'm sure you know that.
    Or can you trip the RCD with a connection from the audio earth to the CPC ?, on either item with the other item not present.
    M
