EIC test details - only put new work circuit details?
Hi, filling in a EIC.
Do you only specify the new work circuit details?
For example, I just did a consumer unit change with a new kitchen ring, altered the cooker circuit, additions to the lighting circuit, alteration to the sockets downstairs circuit.
Filling in the test results, do I N/A the circuit specifics (type of wiring, cable sizes, reference methods, points served) for the existing circuits that I didn't work on and only specify the new work that I installed?
Examples:
Say I didn't work on the upstairs sockets, or loft sockets, I'd N/A them circuit specifics?
The original lighting is 1mm, reference method unknown, now with 14 points. I installed 1.5mm, ref 100, with 6X downlights, so do I put 1.5mm and my reference method, 6 points?
I altered the cooker circuit, its a 6mm, ref unknown. I added a setup for 2 ovens on 2.5mms. Do I put 2.5mm?
I fitted an isolator for the shower but installed no cable. So do I put N/A for them circuit specifics if I only specify the new work?
Confusing!
