Question about metering solutions.
Am looking for a quick and cheap solution to a requirement to provide metering for a single appliance, in this case a dairy fridge/chiller for a farmer.
The refrigeration unit is on a 13A plug and socket. and I thing the max draw when the compressor kicks in is only around 1.5A.
The guy wishes to 'rent out' the unit for a third party to use and he needs to  know how much to charge for it's electricity consumption.
What would be the easiest solution to this? Leave the existing socket outlet alone and just insert some kind of meter in line with the appliance flex? (If such an item exists)
Or just insert a meter between the supply and the socket outlet concerned. Note: metering is not possible from the consumer unit end.
A 100A meter seems like overkill for what is actually needed.
Comments welcome.
  • The situation is simply this - the farmer is giving up his milk round - he used to buy milk in from a local dairy and provide a sales/delivery service. This will no longer be the case because he wants to partially retire, and someone else has asked if they could take it over. All they want is the use of the fridge.
    The farmer asked me today if I could fit a meter to measure the consumption of of the fridge unit (commercial type) so that he knew how much to charge the person who is taking over the use of the fridge for the amount of electricity it is using. He is concerned about the rising costs of energy, and didn't want to lose out by undercharging. I think it will be just case of charging a cost price rather than to make any money out of it.
  • Ok, so we are not talking about the exotic locations pampering to the ultra conscience over subscribed over inflated expectation are we.
    So we make a quarterly, winter, spring, summer autumn assessment and apply these expected costs to the bill.
    As we have established that It's not an hourly frequented knocking shop... is it?
  • I do apologise, I didn't see your post.
    edit: which actually appears to be mine.... this is intended for whJohnson.
    I don't think you can be that accurarate when making an assessment while the price of energy is vacillating while a prospective Zcar, Czar attempts an ecomomic pact with a prospective emperor. As we well know the most trustworthy assessments were made by the electrical companies over a period of years, One hopes you will continue to do businses for many years to come using well established methods.
  • Folks, many thanks for the ideas/tips etc. I like broadpage's idea - fcu-16A CEEFORM plug etc. Will see if there's a little panel I can make up in which to house the meter.
    Who knows how the future will turn out in terms of energy prices etc? We need to start digging for coal, drilling in the N.Sea for gas, and drop all of this green nonsense in order to regain some national resilience against global prices. Meanwhile, I will simply comply with the customer's request and get on with the job of fitting the meter. What he does with his readings and whichever way he uses them afterwards is no concern of mine, so long as I get paid for the job.
