AFDDs NEW REGULATION IN AMD 2
As you may be aware amendment 2 to the 18th Edition was published in the early hours of this morning. If you have the access to the IET Digital package you may have already seen this change.
The new regulation is.
Arc fault detection devices (AFDD) conforming to BS EN 6206 shall be provided for single phase AC circuits supplying socket outlets with a rated current not exceeding 32A in.
High Rise Residential Buildings (HRRB)
Houses in Multiple Occupation (HMOs.
Purpose built student accommodation.
Care homes.
For all other premises, the use of AFDDs is recommended for circuits supplying sockets not exceeding 32A.
So we will not be seeing consumer units full of AFDDs if at all in ordinary domestic premises.
Lights blue touch paper and retires.
JP
  • It is my understanding that AFDD will be useless on the majority of UK domestic lighting circuits and installing to lighting circuits is akin to ripping up £50 notes.
  • At least there is a level playing field where “mandatory” application of AFDDs is concerned but it would be foolish for any designer to ignore a “recommendation” made for their deployment.  Some courage will be needed by bodies like NICEIC to offer advice to contractors operating in the domestic sector as to an appropriate approach.
    Given the mandatory requirements, it seems clear that the purpose is one of life safety rather than property protection and that some scrutiny of fire statistics has been used to prioritise the risk. However, there will be many instances where private dwellings will display a similar risk profile and thus AFDDs should be at least run through a risk analysis.
    I am sceptical about the benefit of the devices generally and I imagine if there really was sound evidence to demonstrate significant reduction in risk, the mandatory net would have extended to all areas with sleeping risk. I guess cost was the biggest impediment to the decision to only recommend them in the general domestic sector so the next best thing is to shift the burden on to the designer.
