Another garden room wiring question
Despite the weather I have built the shell of the garden room and will sooon be ready for the electrician.
We agreed that the SWA would run up the outside of the cladding to a junction box then T+E from there through the cladding and SIP wall, which comprises polyurethane insulation sandwiched between two sheets of OSB. I will be drilling the hole for the cable and would like to run it rhough a pipe, e.g. 22mm plastic pipe. Is that acceptable, if not what else could be used?
  • Sorry ebee!
    SIP = Structural Insulated Panel (a sandwich of insulation between two sheets of OSB)
    OSB = Oriented Stranded Board
    PU = Polyurethane
  • OK these are laminated panels with a layer of "oriented strand board" on each side of a polyurathane panel as insulation, typically used in timber frame construction. OSB is sometimes called wafer board as it is made from thin slices of wood glued together, like giant chipboard. It may or may not be waterproof glue so beware! SIP is something insulated panel, like CU and fuseboard!
  • David
    It's a 32 A circiuit and I think the electrician advised 6mm2 SWA.
    The building will be clad with tongue & groove cedar. The spacing between the cladding and the SIP wall is only 25mm so the SWA will be run on the surface of the cladding. It's the back of the building so can't be seen.
    I was planning to use a hole cutter with an extension bar to go through the SIP wall, insert and seal PVC conduit then fit the cladding over that.
