Solar Hot Water System
With hot water solar heating panels that heat a copper cylinder with no pump, to an internal heating coil, does the "flow" from the solar heating panel run to the top of the coil in the copper cylinder or the bottom, bearing in mind that with a gravity system hot water rises?
