Installation of CT clamp current monitoring devices
Hi there sparkys!
I work for a company who manufacture CT Clamps to measure current consumption. I'm a presales engineer, not an electrician.
These clamps, as I'm sure you know, simply clip on to a conductor in a consumer unit or elsewhere, and in our case, transmit the information wirelessly to a device which translates and presents the data in a useful fashion.
I'm working on some marketing documentation, and I'd like to be clear about the legality of installing these devices in commercial premises. In order to install these devices, one simply has to clip them around an insulated live conductor, there is no need to turn off the power, or touch any bare metal. I know that British Gas and other companies hand these out to domestic consumers so that they can have a display showing how much energy they're using, so I assume that it is legal for any old idiot to clip these on to an insulated live conductor in a domestic consumer unit.
But what about commercial premises? I don't know the rules - can an unqualified/uncertified person open a RCD box or consumer unit or whatever it's called and clip these CT clamps on to a live conductor in commercial premises? Can an unqualified person even touch a commercial consumer unit?! I would have thought that regs would require a certified electrician to install these things, but one of our selling points is that they don't require professional installation or any permanent modification to the wiring, as they simply clip around an insulated conductor.
I've attached a picture of some of these clamps installed in one of our consumer units. These were actually installed by a certified electrician, but only through coincidence - the guy who did my job before me just happens to be certified, as he worked as an electrician before he started this job!
Any advice on the legal requirements of installing such devices would be appreciated. Obviously it's very important that our marketing materials don't advise anyone to break the law!
I'm asking this question from the UK, but we sell these devices globally, so any advice on different rules in Europe or America or anywhere else would also be welcome.
Thanks everyone!
  • Oh wow, that Wylex link you sent me is exactly what I have in my house! I'm selling the place at the moment ,thank God!!
  • Well before you go, switch it off, remove all the fuses and then take a small screw driver to it and use the opportunity to open it up for yourself and see what exactly is inside a  consumer unit for real.  It is not always like the sales pitch photos on the  websites you know ;-)
    keep your fingers off the bare metal and..
    then put the lid  straight back on...
    and realize why the instructions must ask folk to refer to someone suitably skilled when it involves opening something up.
    There is plenty of that older stuff still in service, even if it was last installed in the early 2000s, your instructions must allow for that.
    ps the brown ones are more 1960s ,but the white ones of more or less the same style were sold and being  fitted until about 2005. (and I last put one in in about 2002 personally....)
  • Regulation 536.4.203 of BS 7671 contains the following statement (applies to BOTH domestic and commercial/industrial):
    In low voltage assemblies to the BS EN 61439 series, e.g. consumer units, distribution boards, incorporated devices and components shall only be those declared suitable according to the assembly manufacturer’s instructions or literature.
    Which really means that, either:
    (a) The manufacturer of the consumer unit has to declare the current transformer is OK to install in their; or
    (b) The installer takes responsibility for all aspects of the safety of the consumer unit (or distribution board) from when the current transformer is installed in the product.
    Many current transformers' outputs are not limited if the CT circuit goes open-circuit - effectively FELV rather than SELV or PELV, so wiring outside of an enclosure must meet requirements for mains cabling (insulated and sheathed, or in suitable containment).
