EICR - does bathroom lighting outside zone 2 need to conform with IP rating and additional rcd protection?
Hi, I have received an EICR certificate with 2 C2s on bathroom lighting 1) Bathroom lighting does not conform to IP rating (note the lighting outside the zone based on published zoning guidance (low voltage spot light) but inspector insisted on ignoring the zoning guidance) 2) Bathroom lighting circuit is not connected to an RCD also supplementary bonding is not visible.
Questions- 1) Are the C2s legitimate? As a layman, I find it difficult to understand why the inspector insisted on ignoring the bathroom zoning regulation (my ceiling is actually higher than most of the newer flat) . 2) Also how do I find out whether there is supplemental bonding in the bathroom lighting circuit (nothing is visible outside) - does it really warrant a C2 if I cannot prove that there is supplemental bonding (the lighting in my bathroom is low voltage (I don’t know what is the voltage but it is very dim) and is located outside zone) . 3) If the C2s are legitimate, how can I fix the issue with minimal cost?
many thanks for your time in advance.
  • 12pm - there is no such time as 12pm or 12 am
    Not quite true ... I agree that neither of the monikers am (ante meridiem) nor pm (post meridiem) are valid at precisely the instant of noon or midnight.
    However, it's also true that the clock time in minutes is "12:00" for 1 minute, and therefore (because dt tends to zero):
    • at 12:00 ({midnight+dt}<t<{midnight+1minute-dt}) it's 12 am; and
    • at 12:00 ({noon+dt}<t<{noon+1minute-dt}) it's 12 pm.
    ... and that's Engineering Grinning
  • The use of "noon" and "midnight" avoids any confusion.
    One can certainly use "12:00" for noon, but because of the ambiguity of "00:00" on Saturday, for example, nothing ever happens then in military circles. Events happen either at "23:59" or "00:01".
  • However, it's also true that the clock time in minutes is "12:00" for 1 minute, and therefore (because dt tends to zero):
    One might equally well argue that it is 12 (am or pm) for a whole hour (to 2 significant figures).
  • One might equally well argue that it is 12 (am or pm) for a whole hour (to 2 significant figures).
    Absolutely, if you are using times that are truncated to the hour, rather than the example of a more common digital or analogue clock display often truncated at the minute resolution, the same logic persists.
  • Fittings like these are still available and can be bought for £2.27 each including VAT.
    However add on a transformer, lamp and fire hood; and they cost more than a reasonable dedicated IP, fire and acoustic rated LED downlight that is more economical to use and is actually fit for purpose.
    These fittings were rarely fit for purpose and generally  badly installed,having said that I still have three in my bedroom in a bulkhead over the wardrobe doors, but they are mounted in such a way that the integrity of the ceiling above them is maintained.
    These days I would not entertain fitting them in my own home or anyone else’s either for that matter.
  • I still haven’t back from the vendor (they are an intermediary that provide landlord certification service/) that assigned the EICR inspector to me re NICIE technical’s views on the 2 C2s (recap - C2 not valid on bathroom lighting and the rcd C2 point needs to test supplemental bonding to confirm).
    But I have just received a quote from the vendor for remedial work and reissuance of a new EICR for less than 200 pounds. One thing that puzzles me is that the quote description only covers replacing two bathroom lights to IP rated. May seem silly to ask - does it mean that one can just replace the bathroom lighting to ip rated light to ensure compliance to RCD protection / supplemental bonding for lighting circuit condition? Thanks
  • next issue - what date does 12 midnight belong to? is it 31st of Dec or 1st of Jan for example , you`d have to specify both dates to inform the reader which midnight it was. If you just gave 12 midnight and one date it would be misleading
  • Well the main question in relation to time is "where does it all go?"
    I've been googling military time and there is no 2400, it reverts back to 0000 at the very stroke of midnight. This does away with any confusion about having to use two dates to pin down which midnight you are talking about, since 0000 on any given date is the very first thing in the morning. But as Chris said earlier, military like belt and braces solutions, so makes complete sense to do stuff at 2359 or 0001 instead
  • Can anyone please help me with this -  the inspector now offered to move the lighting circuit to the RCD section for free (I didn’t ask for this) because they said they can’t amend the issued EICR report otherwise.  I know this is not ideal because someone had said that this could pose issues in future with lighting out when sockets are out. Can I ask whether the risk means that I will end up having to replace all lights and the wirings if sockets become faulty in future? ( Sorry if I’m asking an obvious question because I really don’t understand what are in store for me if I go down this route). Thanks for your help!
  • Just to add - the inspector didn’t want to test the supplemental bonding  hence he is offering this (via the intermediary)
