RCBO tripping
RBCO trips when I switch off circuit, can only reset by closing light switch, circuit has been working normally, suspect condensation but still odd
  • THanks wh it may be worth a try
  • It doesn’t trip with the lamps out
    But also doesn't trip with the lamps lit? Still sounds to me like a fault between switch and lamp - either the switch in the off position is shorting to something (e.g mis-wired 2-way switch) or reverse polarity with an earth fault on the switch line.
