Non-UK & Non-EU Socket Outlets used in the UK
Hi All,
This is my first post so excuse me if I do something wrong.
I've been asked to make some special plates for a hotel that contain multinational sockets.
I have always presumed using EU sockets was acceptable under the harmonized standard but the standard specifically says
511. NOTE 2: The use of foreign national standards not based on an IEC Standard, and/or not compatible with the safety provisions
of BS 7671, is not recommended.
The job I've been asked for is to add Type I  AS 3112 (Australian) & a Type N SANS 164 (South African) mains socket along with other connections and switches.
Although the items carry approval of their native country, can they be used or is the entire safety obligation on the specifier and installer?
On the flip side of this question, can I do a similar job in France where they want small BS516 round pin plugs?
  • Isn't the socket-outlet covered by Regulations 4(1), 5 and 10(1), i.e. standard socket-outlets 'ordinarily intended for domestic use' (as it's put in the legislation) should be to one of the standards in Schedule 2 (items 1 to 3 for socket-outlets of course)?
    Hard to be sure - it seems like a particularly opaque bit of writing to me. As far as I can tell so far, while the regulations apply to all domestic sockets, the requirements of the regulations (Electrical devices other than standard plugs- reg 6) only apply to what's listed in column 2 of schedule 3 - and a socket for flat pin AUS/NZ plugs doesn't seem to fit any of those categories.
    I'll have to have another go at reading the "The Plugs and Sockets etc. (Safety) Regulations 1994" when I've got more time to spare - but my gut feeling is that it can't boil down to "all domestic sockets must be to BS 1363" (or older round-pin BS standards) - otherwise we'd be banned from having LSCs on wall lights or EV charge points at home.
  • "[Reg] 4.—(1) Subject to the following provisions of this regulation, this Part [I] applies to the following devices namely any plug, socket or adaptor ordinarily intended for domestic use ..." (my emphasis). It seems fairly obvious that a hotel room is not domestic.
    Part II applies to appliances only.
    But it doesn't say "applies to the following devices namely any plug, socket or adaptor when used in a domestic environment" - 'ordinarily intended' seems to be referring more to the type of device than where it is actually used.  (Which sort of makes sense when some of the requirements are along the lines what sort of fuse can be fitted to a 13A plug). I still find much of the wording to be as clear as mud.
