Public Consultation: PAS 63100 Electrical installations – Protection against fire of battery energy storage systems for use in dwellings – Specification
The Draft of the new PAS 63100 standard for protection against fire of battery energy storage systems for use in dwellings is now available for public comment on BSI’s Standards Development web-site.
The public commenting period commences 26 June 2023, and on closes on 24 July 2023.
This topic is directly related to domestic storage installations accordance with BS 7671 and the IET Code of Practice for Electrical Energy Storage Systems.
  • As I understand the situation it is not the stored electrical energy that is the problem but the various elements used to construct the battery that will burn without an external oxygen supply. Petrol and diesel fires can be extinguished by cutting off the oxygen with foam or powder. The lithium based batteries keep burning.
  • This can also be taken one step further.  1 EV on fire can ignite the next EV on fire thus causing a chain reaction of fires igniting with a furiotious burn akin to a rocket taking off
  • 1 EV on fire can ignite the next EV on fire thus causing a chain reaction of fires
    same with liquid fuel vehicles.
    A bit of both I suspect. I would have thought conventional firefighting techniques (e.g. water) could keep the area around a burning EV cool enough to prevent the fire spreading, even if its own batteries continued to pyrolyse.
    For comparison, thousands of petrol/diesel vehicles bust into flames of their own accord every year (often due a simple fuel leak in the engine compartment) - happened to a good friend of mine on the motorway a few years back in an almost new car. Things can be a long way from perfect and still be no worse than they are already.
  • One very interesting observation:-
    • The (draft) BSI document on how to install batteries in a house: 24 pages long.
    • The (draft) IET document on how to install an electric car charger: 249 pages.
    Another interesting observation.
    The (draft) BSI document refers for the electrical requirements to BS 7671 (600 pages long) and the IET Code of Practice for Electrical Energy Storage Systems (174 pages long), and BS 5839-6, etc.
    The issue being, the BSI document ONLY covers fire safety requirements for installing battery storage systems in DWELLINGS ...
    And, although I know I've replied to this point you've raised before, the draft contained tracked changes, so is around 50 pages longer than the final version will be ...
