In a UK domestic dwelling would/should you wire an oven and/or hob in H07 Flex or T&E (PVC/PVC)?
Some MI (manufacturers instruction) for oven and/or hob state H07.
Some MI for Cooker Outlet Plate state T&E.
Some MI for the oven and/or hob/Cooker Outlet Plate lack any guidance and say consult a qualified electrician.
Another thing to consider is, if the MI for oven and/or hob state H07 and MI for Cooker Outlet Plate states T&E, are they incompatiable?  Personally I think H07 Flex should be used for Oven/Hob thus the oven/hob can be removed for cleaning or maintenance purposes.  It is also heavy-duty rubber designed to provide high flexibility and to withstand chemical, mechanical and thermal stresses and normally UV stable.  It would be nice to see what BS7671 states and what the community thinks and what the manufacturers state or  think.
  • I would consider that HO7 flex is preferable on the grounds of flexibility and heat resistance, but that twin with earth is just about acceptable
    H07 might not be suitable for some heating appliances, due to temperature particularly at the terminations or close to the appliance ... same problem with "standard" PVC, whether rigid or flexible.
    I know some people in the industry would go for "heat-resisting" flex rather than a 70 ºC conductor operating temperature cable.
    Manufacturer's Instructions all-important !
  • Hi Sergio, yes the brown coloured cable was once SY flex for Air con. Installed on a flat roof in sunny Manchester.
  • I nearly always use H07. Seems the best bet to me unless instructions say otherwise. I fitted an oven recently, that had been repaired by an appliance engineer after overheating and melting the plug, socket and 1.5mm flex that was used to supply it. The instructions specified 4mm H07, it was dam near impossible to get it under the cable clamp in the terminal box. This is a frequent problem I come across.
