A Friday Debate
Should older or earlier versions of BSI standards be made freely available on the internet?
Consider for example
BS 7430:2011+A1:2015. Code of practice for protective earthing of electrical installations being the current version
BS 7430:1998. Code of practice for earthing Published:15 Nov 1998 • Withdrawn: 31 Dec  2011
Or maybe
BS 7671:2018+A2:2022. Requirements for Electrical Installations. IET Wiring Regulations being the current version
BS 7671:2008+A3:2015. Requirements for Electrical Installations. IET Wiring Regulations Published: 31 Jan 2015 • Withdrawn: 29 Jun 2018
These could be published in a PDF format with a watermark on every page stating that this is not the current or latest version and for the current version can be found on the BSI web site.  This then allows people to look at the information from older versions and allow them to use it for research or for study purposes.  If you take BS7671 as an example has over 60 Normative References to other BS standards like BS 5839 which in effect is a whole suite of standards.  Sometimes people are unsure if that publication will satisfy their requirements.
As a scenario BS7671 makes reference to BS7430 and BS7430 makes reference to BS7671
As always please be polite and respectful in this purely academic debate.  The concept of this idea is to help educate future generations of engineers by allowing them to access historical information from past achievements and standards.
Come on everybody lets help inspire the future.
  • It is irrelevant if an installation of a piece of equipment complied at the time, the important issue is does it comply with the current standard.
    I disagree with this. Legislation isn't generally "retrospective" and standards are the same. Only a court can decide what precedence is an issue.
    I do, however, agree that, for continued service of workplace equipment, the duty-holder may need to make decisions about a product or installation vs current standards (risk assessments have to be reviewed when legislation and standards change).
    I have to ask why you want copies of withdrawn standards other than for historical interest?
    Ongoing (sometimes very long-term) projects, where standards change from the dates for standards and legislation baseline agreed in the contract.
    Also experts looking at legal cases which must consider standards in force at the time in question, or changing over time periods in question, in the case.
    I'm not so sure. Say you were inspecting an old installation that had say BS 3871 MCBs. Do they meet current standards? - almost certainly not, but an EICR is more than that. The real question is are they safe for continued service - e.g. will they meet modern disconnection times in the situation you find? Where better to find that data than from BS 3871 itself? Even though it was withdrawn years ago. (OK, you could refer to some other text that has a copy of the same data, but doesn't that amount to the same thing, in principle).
  • Afternoon Andy
    For BS 3671 circuits breakers much better to look in the IET On-Site Guide which has a table for BS 3871 max values of Zs without needing to calculate the value from the BS 3871 standard itself.
    JP
  • Can I play devil advocate and say
    The Housing (Scotland) Act 2006 changes
    A valid EICR does not mean the dwelling is compliant as it may not have an RCD present
    You can, but looking at that very act I have failed to find any reference to an RCD, or indeed any reference to BS7671 or any other British standard either.
    Rather the requirements is much more general.
    "A house meets the repairing standard if—
    (a)the house is wind and water tight and in all other respects reasonably fit for human habitation,
    (b)the structure and exterior of the house (including drains, gutters and external pipes) are in a reasonable state of repair and in proper working order,
    (c)the installations in the house for the supply of water, gas and electricity and for sanitation, space heating and heating water are in a reasonable state of repair and in proper working order,
    (d)any fixtures, fittings and appliances provided by the landlord under the tenancy are in a reasonable state of repair and in proper working order,
    (e)any furnishings provided by the landlord under the tenancy are capable of being used safely for the purpose for which they are designed, "
    now if an inspection to that standard requires the addition of an RCD where there is not one already is clearly a matter of judgement- and it may well be good practice and normally done, but it is not clear it is legally mandated at all and the law as such says nothing to do with BS7671.
    Unless you have a link to more definitive reference of course...
  • Hi Sergio, things could get messy, if users don’t know which standards are the newest and latest ones, or if they use old or cancelled standards by accident for their work. It might also hurt BSI’s revenue, if users can get their standards for free.
  • Also experts looking at legal cases which must consider standards in force at the time in question, or changing over time periods in question, in the case.
    Indeed. If somebody suffered harm as the result of a poor installation, it would be judged against the standards of the day in any claim for negligence.
  • Compared with other standards, BS 7671 is pretty cheap. That may be because it is sold in much greater quantities than yer average Standard, or perhaps the aim is to encourage compliance.
    Previous editions can be found on eBay pretty cheaply.
    I'd like to see British Standards much more freely available. At one time Hampshire CC libraries subscribed, but not for many years.
    Laws must be freely available and clear so that people can see what they have to do to comply. I think that the same could be said of BS EN ISO standards. However, there is a difference between a manufacturer buying a copy of say, BS 1363 to ensure that their plugs comply on the one hand, and a consumer who wishes to check that the plugs that he has bought do indeed comply on the other hand.
    So should the BSI be nationalised and funded by the tax-payer?
  • Hi Mike
    I think the gist of it is
    1st March amendments come in to force
    Rented dwelling need 30mA RCD protection if any amendments have been made.  (In affect bringing up to current standard)
    Craig from Quinnergy explains it better on YouTube (Changes to The Housing (Scotland) Act 2006 Explained)
    about half way through the video.  First half is about lead levels and the need for testing for lead.  URL below
    youtu.be/-aJ-XHJjetI
  • Rented dwelling need 30mA RCD protection if any amendments have been made.  (In affect bringing up to current standard)
    It still wouldn't be quite that simple ... it might also depend ion whether the project was already underway (whether or not electrical work has started) - for building control purposes there are dates by which work has deemed to have started.
    When construction contracts are involved, things get a whole lot more difficult, because a contractor may not be enabled to make a "change" decision on their own ... the contract variations procedure must be followed.
