Notifiable or not
Hi,
Seeking some clarification on Part P.
Existing 6mm cable protected by a 25A RCBO in main CU. Is an upgrade to a 40A RCBO, notifiable under Part P? It isn’t a new circuit, only a modification which after modification, complies with BS7671. Thoughts?
The current 6mm cable is sized down to a 4mm cable in a junction box and then goes off to feed 2 socket radials.
Would adding 2x OCPD (for example 16A MCBs) at this junction point, be seen as a “new circuit” or would this also be a modification? At present, these OCPD don’t exist, so would need adding from a new DB.
I am no longer Part P registered to self notify, and albeit I want to do this myself, I also want to do it properly so if I need to outsource any of this I can (but would much rather not!).
Thanks.
  • It's not "gov guidance for part P".
    It is Regulation 12 of The Building Regulations, which are the law.
