I have heard whispers of a compound that can be used to backfill, loose-fitting earth-rod holes to impove the connection to earth. Anyone done this? Thanks
"Bentonite (/ˈbɛntənaɪt/ BEN-tə-nyte) is an absorbent swelling clay consisting mostly of montmorillonite (a type of smectite) which can either be Na-montmorillonite or Ca-montmorillonite. Na-montmorillonite has a considerably greater swelling capacity than Ca-montmorillonite."
I need a babel fish Zaphod :-)
(At least I've learned something new too.)
Gypsum/bentonite mixes are routinely used for earth electrodes to reduce the contact resistance. It is a hygroscopic mix and benefits from an initial good soaking when it is installed. If you interested I can pass on the gypsum bentonite mixing ratio.
