Flexible 'tails'
I was working on a job the other day where an e.on man was fitting a smart meter.
In converstion he told me that e.on were taking out any flexible tails they found fitted between the cut out, meter and any isolator installed.
From the meter or isolator, the customers 'tails' if flexible would of course be left installed.
Seeing as how I'm trying to save more wear and tear on my digits which are now suffering badly after years of bending 25 & 35mm2 'tails' I'll keep using flexible 'tails' untiil I'm told oficially a reason not to.
Apparently this doesn't apply to various other service providers.
  • 1 strand out of 19 hardly counts as a whisker in my world.
    it's over 5 % of the metal part of the cross-sectional area. However, with larger csa, given the skin effect, it may well represent sizeable amount of the actual conducting cross-sectional area at the point of entry to the terminal, especially as the dropped strand will be on the outside of the bunch !!
    Luckily skin depth in copper is 8-9 mm at 50 Hz, so unless you've got lots of harmonics, at 35 sq mm the skin effect isn't too much of a problem.
  • I think the other Grahams point was  that unlike the superfine stranded stuff with 0.1mm cores or whatever this is still quite chunky - the chances of leaving a strand out and not realising in reality must be pretty small - comparable to cases where the meter changer forgets to tighten something - which is also very rare but not quite never. In terms of stress on the terminals, the  7 strand is quite wilful ;-)  It would be hard to imagine a terminal that holds 7 strands and fails to hold 19 - but for a maker not to have bothered to test it and say so , that I can easily believe.
    M.
    Nearer to 1.5 mm² than 1.0 mm². You could make a whole circuit out of that!
  • Bit of confusion creeping in here
    Mapj1 posted
    I wonder if Eon are worried about a stray whisker short circuit problem, either real or imagined.
    I replied
    By that I meant 1 strand out of 19 is way bigger than a whisker. I'm sure the whisker he refers to is in a multistrand flex which is not the sort of cable I was talking about.
    To be honest I probably should have started the post with the heading 'Flexible tails'
    All I can say is that if I rack up @ my local wholesalers and ask for 25mm2 Class 2 stranded circular conductors, I'm going to get some blank expressions..
    Still doesn't explain e.ons policy oh and apparently they've ditched their 10 hour off peak tariff and are only offering a 7 hour off peak tariff but that's discussion for another day
