SIMULTANEOUS CONTACT QUESTION - 2 x EV vehicles parked next to each other
Scenario
A remote block of 3 garages, 2 will be fed from separate properties via 40m of 10mm EV SWA connected to 2 individual new CU's
( no cars will be parked inside the garages but charged on the drive in front of the garage door)
1 property is TNC-S - Ze 0.30 Ohms and the other is visually a TNS but with Ze 0.32 Ohms and similar L-N reading.
The 2 chargers will have Pen fault protection and the relevant RCD protection as usual.
There are underground services within 1 -10m of a potential TT rod so could be problematic and a maximum 2.5m between separate garage earth rods is possible.
The concern is simultaneous contact between the 2 vehicles.
Regulation 411.3.1.1 states that “simultaneously accessible conductive parts shall be connected to the same earthing system individually, in groups or collectively.”
I am currently waiting for UK Power networks to confirm the 2 properties are connected to the same earthing system.
The questions are:
Is Pen fault and RCD protection enough when connecting both cars to TNS/TNCS or is there anything else we can do?
Is separate TT earth rods along with simultaneous risk assessment the safest option in this case?
Thank you
I've attached a sketch of the current proposal to help explain.
PDF
  • Hmm. that's the weight of the complete compressor and every thing
    Indeed - that's for a monobloc system (the most popular these days I gather as it avoids having to charge refrigerant lines on-site as is the case with 'split' systems). There's yet another variant that runs the "brine" circuit between indoor and outdoors, and as you say the outdoor unit it little more than a heat exchanger and fan (and a de-frost heater) but for some reason that's only available in a 3-phase version (and won't de-frost from the heating circuit Disappointed)
