Consumer Unit proximity to combustible material
Good afternoon
We are looking into installing a metal consumer unit within a wooden kitchen cupboard.
I was looking through BS7671 but cant find any reference as to how close can the CU be to a wooden surface since the wooden cupboard that would host the CU could be considered as a combustible.
Am I missing something?
Is there anything in BS7671 I have missed?
We are looking at the minimum dimensions that the kitchen cupboard needs to have in order to host the CU.
  • Hello  Mike:
    Breaker boxes can cause fires.
    I had to have my main house breaker box replaced a few years ago because the design of this unit would allow (over time) high resistance connections to develop, There was also  a US Fire alert on this specific design/manufacturer.
    Prior to getting it replaced one was advised to place one's hand on the box cover to see if it was getting warm to the touch once a month.
    In fact my property insurance company would not insure me, until I got it changed out.
    Peter
  • There was also  a US Fire alert on this specific design/manufacturer.
    Was that the (in)famous Federal Pacific  "stab-lok" ones?
    We had a not too dissimilar situation a few years ago (although not related to any particular manufacturer) where design changes over time meant that some terminals (esp cage clamp ones with large stiff conductors) tended to overheat, and the plastic enclosures weren't quite as fire resistant as most expected. Modern consumer units (mostly with steel enclosures) are meant to have mitigated that risk.
  • Yes Andy:
    That was the manufacturer!
    Peter
  • The keys for the cupboard belong to the hotel staff that is managing the hotel. Obviously the tenant will have no access to this and will have to call for help from the hotel staff in case there is a problem.
    Do you and the occupier really want the inconvenience in the (hopefully, unlikely) event of a tripped circuit?
  • Yes Andy:
    Peter
    Got them at home - circa 1982 vintage. Never been a problem! Mind you, the UK ones my be a different spec from the USA ones.
  • Hello Chris
    Mine was installed in the house when it was built in 1970!
    Peter
  • Hello Andy:
    This brings up a very interesting question -- Who in the UK determines if the proposed design change (example using plastic parts) is a "major" or "minor" change?
    One of my jobs at one US company was "Configuration Control" and I was the person who made that "major" or "minor" change decision!
    Peter
  • Part M will also apply to the staff and there are laws about discriminating against disabled people when recruiting.
    I also agree with access for maintenance and testing. Trying to reach into a cupboard especially when on a ladder or step up makes everything so much more difficult/dangerous
  • I'm sure from the hotel's point-of-view, that's a very strong "yes".  They don't want occupants fiddling with the electrics.
  • I have seen DBs placed in questionable positions in a lot of apartments / houses in the UK. I think the BS7671 regulations need to give a more definite answers to aid safety of occupants & ease maintenance.
    Placing a CU high away in a kitchen cupboard is just one of the many cases. As an electrical design engineer, I believe a proper review of the apartment would help identify better suitable locations. Look around for some dead space maybe behind the kitchen door.  I would suggest a mounting height of about 1.8Mtrs AFFL to top  frame. A recessed enclosure with locks would be a good fit.
