Earthing and Bonding Design for 690V AC Railway Tunnels
Dear IET Technical Team,
I am an IET member (MIET) currently reviewing the earthing scheme for about 5 km AC train 960 VAC tunnel supplied from two substations (each with separate earth electrodes, ≤5 Ω). Both substations are interconnected by two paralle
System Configuration Overview:
  • Each substation is equipped with its own earth electrode system designed to achieve a resistance of ≤5 ohms.
  • The substations are electrically interconnected via two parallel protective earthing (PE) conductors that run along the full tunnel length (5 km), ensuring both equipotential bonding and redundancy.
  • These PE conductors are intended to:
    • Interconnect both substation earthing systems,
    • Provide a continuous protective earth along the tunnel for all connected equipment (lighting, SCADA, signaling, etc.),
    • Bond all exposed conductive parts and metallic structures inside the tunnel.
  • I would appreciate the IET’s expert input on the following aspects:
    1. Is the use of only end-point earthing (via the substations) with continuous PE conductors across 3 km acceptable for a 690V AC system, assuming the conductors are adequately sized and bonding is done at regular intervals?
    2. Would additional intermediate earthing electrodes or equipotential bonding bars be recommended, especially to mitigate the effects of fault current return path impedance or potential rise under earth fault conditions?
    3. Are there any best-practice thresholds for voltage drop or rise along PE conductors during fault events in such long LV systems, particularly with respect to maintaining safe touch and step voltages in a tunnel environment?
    4. Which standards would best guide this setup from the UK or international perspective? (e.g., BS 7671 Section 542, EN 50122-1 for railway applications, IET Code of Practice for Earthing, or IEEE Std 80?)
