I am a massive waffle fan. I don’t, however, have a waffle maker, otherwise I would forever be eating them and staying inside. Because waffles are so much better than having a social life.
Anyway, this product seems to encourage you to play with your food, which is pretty much not what I’ve been instructed to do my entire life, but hey.
The Building Brick Electric Waffle Maker creates 14 interlocking building-brick-shaped wafflies. You can stack them up and make structures like towers, houses, or spaceships. You could even cut the little pieces up and make dragons or waffle monsters.
I’m not sure how well the interlocking of the bits would work, unless you like your waffles solid as... well... bricks.
The Waffle Maker can create 10 short bricks, two long bricks, and two individual bricks at the same time. The aluminium die-cast moulds are non-stick, you plop in the batter and you’ve got...
