University of Toledo physicists might have solved the problem with the durability of perovskite solar cells, taking the technology one step closer to powering solar panels in the consumer market.
The team discovered the ingredient that enhances adhesion and mechanical toughness.
Researchers experimentally demonstrated that perovskite solar cells treated with 1,3-bis(diphenylphosphino)propane (DPPP), exhibited greater durability than traditional solar cells.
The discovery could be key to improving the resilience of solar cells. Perovskite solar panels could be easily deposited onto most surfaces, including flexible and textured ones. The materials are also lightweight, cheap to produce, and as efficient as today’s leading photovoltaic materials, which are mainly silicon.
However, it currently faces issues with stability and a short lifespan which decreases further in high humidity, strong sunlight and at elevated temperatures.
“This challenge is no longer...
