Developed by researchers in the US and Sweden, the fabrics could be used in garments that help train singers or athletes to better control their breathing, or those that help patients recovering from disease or surgery to recover their breathing patterns.
The multi-layered “OmniFibers” contain a fluid channel in the centre, which can be activated by a fluidic system. This system controls their geometry by pressurising and releasing a fluid medium, such as compressed air or water, into the channel, allowing the fibre to act as an artificial muscle.
They also contain stretchable sensors that can detect and measure the degree of stretching. The resulting composite fibres are thin and flexible enough to be sewn, woven, or knitted using standard commercial machines, the researchers said. The fibres have an extremely narrow width and make use of inexpensive material. They are also compatible with human skin, since its outer layer is based on a material similar...
