Elon Musk has announced his rocket company will attempt a second launch of its Starship spacecraft after the first one failed its first uncrewed flight test.
The spaceship was mounted atop SpaceX's new Super Heavy rocket, which the company has described as the most powerful launch vehicle ever made. The 120-metre-tall spacecraft lifted off from South Texas on Thursday. However, only minutes after the launch, the two sections of the rocket failed to detach, causing Starship to begin spinning at altitude before exploding about four minutes after leaving the ground.
The test's failure is likely to delay SpaceX's ambitions to use Starship aircraft to take humans back to the Moon and beyond.
Starship rocket ready for launch /SpaceX
Image credit: SpaceX
The goal...
