The flight, which took off from Dubai International Airport, was designed to demonstrate the ability to power flights entirely with SAF as part of efforts to cut carbon emissions from the aviation sector, which is notoriously difficult to decarbonise.
SAFs are typically derived by combining jet fuel with alternatives such as biofuels or recycled oils from industrial food facilities. Currently, SAF is approved for use in all aircraft, but only in blends of up to 50 per cent with conventional jet fuel. Following the successful trial on one engine, Emirates said it wanted to continue to develop the initiative with engine airframe manufacturers.
Emirates worked alongside partners GE Aerospace, Boeing, Honeywell, Neste and Virent to procure and develop a blend of SAF that closely replicates the properties of conventional jet fuel.
Eighteen tonnes of SAF were blended and at each blend ratio a host of chemical and physical fuel property measurements were carried...
