The researchers say the key to their battery is a newly developed electrolyte that is more versatile and robust than traditional materials throughout a wide temperature range. It is also compatible with a high-energy anode and cathode.
Such batteries could allow electric vehicles in cold climates to travel farther on a single charge and they could also reduce the need for cooling systems to keep the vehicles’ battery packs from overheating in hot climates.
Zheng Chen, senior author of the study, said: “You need high temperature operation in areas where the ambient temperature can reach the triple digits [i.e. above 100°F] and the roads get even hotter.
“In electric vehicles, the battery packs are typically under the floor, close to these hot roads. Also, batteries warm up just from having a current run through during operation. If the batteries cannot tolerate this warmup at high temperature, their performance will quickly degrade.”
In tests, the proof...
