Construction work on the facility started seven months ago, and it will occupy around 4 hectares, equivalent to around 0.016 per cent of the total area of the Alqueva reservoir on which it is built.
The new platform has an installed power of 5 MW and the capacity to produce around 7.5 GWh per year, which means that it can supply more than 30 per cent of households in the south Portugal region.
The hybrid project will also include hydroelectric energy generated from the Alqueva dam, which the floating solar panels sit on top of. Plans are afoot to install a battery system with a nominal power of 1 MW and a storage capacity of around 2MWh. All these technologies will be using one single connection point to the existing grid.
Image credit: edp
EDP, the energy firm behind the project, ultimately...
