Working from home is great. I’ve been doing it for more than 20 years, not just since Covid. But one of the things I still miss is ‘water cooler moments’. Not just to chat with co-workers, but to grab a drink instantly.
At the touch of a button, the Aqua Optima Aurora dispenses refreshing cold water and also near-instant steaming hot water for cuppas. Both are filtered. It’s like a worktop version of the boiling/chilled water taps you can have installed at the kitchen sink. And there are pros and cons to this alternative.
The cons are that it takes up worktop space: it’s about the size of a coffee machine (336mm x 221mm x404mm HxWxD). And you need to refill its reservoir regularly, whereas boiling water taps are plumbed into the mains.
The pros are that it’s cheaper than a boiling water tap and doesn’t need installation. Also, you get to choose the volume dispensed. You can simply press a button, leave the cup there and get on with things...
