This cordless cleaner is designed for removing small stains from carpets and soft furnishing. It’s also good for car seats. It boasts two tanks: one for water and detergent, one for the dirty water it lifts. You spray the stain then a power brush lifts it and a vacuum sucks it up into the second tank.
Most rival handhelds just have a brush you scrub with, not a rotating power brush. And it’s Bissell’s first mini cleaner designed specifically for pet stains. At 2kg, it’s half the weight of Bissell’s previous cordless handhelds.
The Pet Stain Eraser arrives ready to use and was quick to unpack. I noted that it uses a 10V charger, rather than a USB cable. The capacity of 200ml and 20-minute battery life aren’t huge, and there’s a long charge time of “less than 4.5 hours”, so it’s best used for little stains when you spot them, not an every-stain-in-the-house cleaning blitz. The good news is that its cordless convenience makes this easy. It’s as easy to grab...
