These are petite Bluetooth earbuds designed to be comfortable even in your sleep, however you sleep. They’re not separate ‘true wireless’ earbuds; instead the two are joined together with a wire.
The design seeks to minimise the size of the buds and ensure that they stay in firmly. Each genuinely fits into your ear without protruding. A spur of silicone points backwards and helps it stay comfortably in place, while the wire goes upwards and then is shaped to loop over the back of your ear. Then the design unusually has a zig-zag of wires leading to a flat, fabric-covered pack at the back of your head. The pack contains controls, an indicator light and no doubt the battery.
There are just three little buttons at the top of the pack. One for power and the others adjust the volume. They’re easy to use in the night but if you’re unsure whether the device is on or off, turning on your phone to check is too wakeful.
The Nightbuds boast a clever design so comfortable...
