Mains-power compatible in practically every country on Earth, the OneWorld 65 International Adapter houses one 65W USB PD charging port with QC; two USB-C smart-charging ports; two USB-A smart charging ports, and a 10A AC universal power outlet, enabling you to charge up to six devices simultaneously. For all but the most rabid gadget enthusiast, this should be more than enough I/O for the modern traveller.
The OneWorld 65 has been designed using Gallium Nitride (GaN) semiconductors, which are valued for their efficiency at transferring current (amongst other chemical advantages) and handling power supply and conversion. The goal here is to maximuse energy transmission to the devices connected to the adapter, with less energy lost to heat. The real-world result is that devices should charge more reliably, consistently and - best of all in an impatient world - quickly.
The OneWorld 65 has also been designed to do all that it does safely, without shorting...
