The one-and-a-half-mile-long structure in Chipping Warden, Northamptonshire, is being built on the surface of the ground to speed up the process, HS2 project leads have said.
Over 5,000 concrete segments made in a factory in Derbyshire will be assembled on-site before being covered by earth, trees, shrubs and hedgerows to blend in better with the surrounding countryside.
The HS2 project has faced fierce criticism about the environmental impact it will have along the full route of the high-speed rail line.
The green tunnel will be an M-shaped double arch with separate halves for northbound and southbound trains. Both halves will be approximately the height of two double-decker buses.
Image credit: HS2 Ltd
According to those involved in the project, the tunnel is the first of its kind in the...
