While the networks powered by 5G technology boast the fastest speeds and the lowest latency, this feat is only achieved by using radio frequencies that struggle to penetrate through physical objects such as walls, ceilings and anything else that might interrupt the line of sight from user to the broadcasting tower.
As a result, 5G networks require a higher number of broadcast points than previous generations and rollout has been slow. For example, BT has said it is working to provide a near-nationwide 5G service by 2028, giving itself a full seven years to fulfil this promise. This is an increase from just 40 per cent of the UK population that can receive coverage on its networks today.
The government’s new project could help speed up the rollout, with CCTV poles, traffic signals and other roadside infrastructure used to boost coverage.
A £4m competition launched today will explore ways to make it simpler and quicker for mobile companies to use publicly...
