The MIT-led 'Mars Oxygen In-Situ Resource Utilisation Experiment' - aka 'Moxie' - has been successfully making oxygen from the Red Planet’s carbon dioxide-rich atmosphere since February 2021, when it touched down on the Martian surface as part of Nasa’s Perseverance rover mission.
By the end of 2021, MOXIE (pictured below) was able to produce oxygen on seven experimental runs, in a variety of atmospheric conditions, including during the day and night, and through different Martian seasons. In each run, the instrument reached its target of producing six grams of oxygen per hour - roughly the rate of a modest tree on Earth.
Researchers envision that a scaled-up version of Moxie could be sent to Mars ahead of a human mission to continuously produce oxygen at the rate of several hundred trees. At that capacity, the system should generate enough oxygen to both sustain humans once they arrive and also fuel a rocket for returning astronauts back...
