Ongoing developments to improve universal access to electricity, while necessary, are unfortunately also undermining conservation work to protect endangered birds of prey and potentially causing population declines in Europe.
The widespread threats in Ethiopia are particularly worrying as the country is a global hotspot for vulture conservation. Endangered birds of prey are being killed in Africa and the Middle East through poorly designed power lines, scientists have warned.
Two papers, published recently in the journal Bird Conservation International, have highlighted the threats posed to globally threatened birds of prey. Large wintering congregations of steppe eagles in the Saudi Arabian desert and Egyptian vultures in Ethiopia are increasingly being exposed to electricity infrastructure that can cause fatal electrocution for the birds.
Most birds can safely sit on a power line without being harmed. However, if a power pole is poorly designed, large...
