The robot, known as the Sample Transfer Arm (STA), is part of a wider joint endeavour between Nasa and ESA called the Mars Sample Return mission, already under way. As of late, Nasa’s rover has drilled eight of an eventual 38 samples of Martian rock and soil.
ESA is currently developing another small rover to retrieve these samples and place them in an ascent vehicle that will carry them into orbit for retrieval and shipping back to Earth via the ESA Earth Return Orbiter.
But ESA’s small rover, the Sample Fetch Rover, needs a sensitive and articulated robotic arm with which to grasp, collect, and transfer the Mars samples once on Mars. This is where the STA comes in.
Image credit: Leonardo/Maxon/GMV/ OHB Italia/ SAB Aerospace s.r.o
“Handling the precious martian samples and getting them ready...
