Some of the most popular shows on television these days are around home improvement. But before any attempt to build or rebuild takes place you need the right tools and a blueprint.
The same is true in data centres. Whether starting from scratch or upgrading and retrofitting, proper planning and design will safeguard speed, efficiency, flexibility and scale in your new data centre.
Our practical guide to Data Centre planning and design has everything you need-from methodologies to at-a-glance calculators. Now is the time to tap into our design guide and ensure your data centre is ready for what’s next.
It is becoming more critical all the time and trends such as the explosion of big data are only adding to the requirements that IT groups must meet. To keep up, companies often need to build out additional data centre space by either adding to an existing facility or building a new one – usually under a tight deadline. It probably should go without saying...
