Insights into how turbulence forms could pave the way for more stable and efficient high-speed aircraft, according to research.
As the cone-shaped nose of an aircraft or missile moves through the air, vortices form behind it. These swirling structures can become large and unstable, often behaving unpredictably. This can cause the aircraft to pull to one side or rotate unexpectedly. In high-stakes environments, particularly military operations, even a slight deviation off-course can mean missing a target or losing control entirely.
To better understand the transition from stable to asymmetric vortices, researchers at FAMU-FSU College of Engineering in Florida, US, examined how different angles of flight affect these vortices. They combined experimental testing with advanced computational simulations to model complex airflow and identify when and how instability develops.
“Aircraft in flight are subject to extreme forces and, as speed and manoeuvring increase, these forces only get stronger...
