When we looked at the upgradable Framework laptop in December 2021, the ease with which it can be assembled, fixed, or undergo a main component swap earned it a rare 10 out of 10 score for repairability from iFixit. All that for a unit that offered the clout of the 11th generation of Intel processors.
Its upgradability is now going to be put to the test. Framework is about to offer mainboards for Intel’s 12th generation (pre-orders were available as this was published). As before, you will be able to buy assembled and configurable laptops, or put one together yourself – a comparatively straightforward process. Just as important, you can install one of the new mainboards to beef up an existing Framework chassis.
This raises an interesting question. Framework wants to promote computing that puts as much emphasis on recycling as it does on repair. To that end, CEO Nirav Patel is encouraging transferring over old mainboards to cyberdeck projects. “We also...
