The X-ray detector was created from tin monosulphide (SnS) nanosheets. It measures just 10nm in thickness: approximately the length grown by human fingernails every 10 seconds. Before this study, the thinnest X-ray detectors measured between 20nm and 50nm.
SnS has previously shown great promise as a material for use in photovoltaics, field-effect transistors and catalysts. The scientists found that SnS nanosheets have other properties, such as high photon absorption coefficients, which make them excellent candidates for use as soft X-ray detectors. Their work found that they were more sensitive than another candidate material (metal halide perovskites) and had a faster response time than established detectors.
These features allowed the scientists to create detectors with high sensitivity and rapid response time.
Although much work remains to be done to explore the full potential of SnS-based X-ray detectors, the researchers believe it could be possible...
