So to summarise, I would try determine the risk incurred by your task and what level of Attitude, Skills, Knowledge and Qualification you need to reduce the risk (would electrical awareness be sufficient? Answering these questions would give you the required training. Then focus on the task itself. Have you sufficient information on what is required, have you given clear instructions and scope (document this), do they have appropriate supervision and technical support should they need to ask for help, Have you made clear what they can and cannot do (work dead as much as possible, put additional controls in place when live testing has to take place, use approved equipment etc.). Arrange regular refresher training sessions (ass required) and audit their work.
Document your assessment and requirements. If you explain it all afterwards to your manager it will help him understand the effort and thought you have put behind making sure you all work in a safe environment and that work is completed in a safe and efficient manner.
Regards, Gareth.
