Back to Basics - TMIET & MIET
I came to the IET web site today hoping for some explanation of what these acronyms mean, and which one is appropriate for whom. Also, some detail on why one would want to be one or the other would be good.
I could find none of these answers. I know these are basic questions, but that is the point. I failed to even find an expansion of the acronyms let alone any other explanations. Just information on how to apply and discussions on whether to do so.
Perhaps I am a bit slow. Please let me know if I missed something obvious!
  • http://www.theiet.org/membership/types/index.cfm
  • Thanks for posting this, James. It illustrates my point rather well!
    There is no expansion of the acronyms "MIET" and "TMIET" and no explanation of why the IET has two parallel membership options and who they are for.
    In my humble opinion, this is where the confusion starts - "what is an engineer?". If the institution can't even get it's language straight and adopt some conventions for distinguishing between "technicians", "mechanics", "engineers", "professional engineers" (does this mean there is such a thing as an "unprofessional engineer"?), how can we expect the non-engineering public to appreciate the difference?
  • Hi John,
    You have some good points there. The next page does expand on it ( www.theiet.org/.../index.cfm ) but I agree - the whole website is geared towards insider use and is not very "welcoming" to outsiders, which is maybe how it is intended.
    John Frankham:
    In my opinion, Professional engineer (or just engineer) means one who earns a living as an engineer. Unprofessional can mean someone who doesn't act in accordance with the principles of good conduct as a professional engineer.
    Non-professional or amateur engineer (or engineer) can mean someone who doesn't earn a living as an engineer; for example, one who teaches say maths or science, but not engineering or works as a finance director or recruitment consultant or is an enthusiast or retired.
    The word engineer - in brackets above - applies to both professional and non-professional.
    If one takes it to the next level then a retired CEng could be classed as a non-professional or just engineer, since they are no longer earning a living as an engineer.
    I tend to think of the difference between a mechanic and technician - as one example - someone who repairs a vehicle, by identifying and replacing faulty or worn out parts; whereas a technician is someone who may have trained as a mechanic, but takes it to the next level, setting up instrument(s) to measure some output and analyse them against benchmark readings - for example when measuring the CO2 output from a car exhausts fume for an MOT test.
    The link below doesn't explain the distinction of job roles between TMIET and MIET and how one can transfer from TMIET to MIET. There are no examples given on how the EU directive works in practice. Without examples, the meaning of the directive is theoretical. And why no EU directive for TMIET?
    http://www.theiet.org/membership/types/designatory-letters/index.cfm
    Roger Greenwood:
    I would describe it as consistent with a large amateur organisation coming to terms with its place in society, following the granting of a royal charter.
    Creating a plethora of membership and registration titles with cryptic style explanations is what makes the IET look amateurish; when describing real job roles - with images of engineers and technicians in their work environment - is what is needed to showcase the IET as a professional organisation.
  • Hello All
    I'm moving this post into a more relevant discussion category as it's not really about 'Using MyCommunity'
    Lisa
  • Mehmood, you have some good points there; and I agree with your analysis. However, this is not how it works in the big wide world. I have often been told "we will send an engineer out"; when the man who is attending is a tecnician or even a mechanic. So without a doubt, the term "engineer" in UK english is devalued, and I think we are hiding our heads in the sand to think we could ever change that in our lifetimes.
    The IET, together with the other august bodies (IMechE, ICE, etc), should together agree a distinguishing term for what we all recognise as a "professional engineer" and stick to it. Rigidly. In all public communications and media activities.
    The next step would then be to insist that only people with the accepted accreditation (CENg, Eur Ing) are referred to in this way.
    0 Former Community Member in reply to Chris Pearson
    Devalued?
    The issue is NOT the English language, nor the vast majority of people that use the language. The issue is a subset of snobs who think they are better (more "value"), rather than just different. You put "engineer" in brackets, yet, the person coming out, by definition IS an engineer
    Oxford English DIctionary
    Engineer
    A person who designs, builds, or maintains engines, machines, or structures.
    That sounds like the "man" who is attending to do the engineering work you cannot do.
    "The next step would then be to insist that only people with the accepted accreditation (CENg, Eur Ing) are referred to in this way."
    Yes, use the jargon of our own little world, oblivious to how the rest speak.
    Good luck trying to get ONLY CEng etc referred to as engineers. NOT going to happen. This has been looked at loads of times by governments.
    Devalued?
    Engineer
    Devalued?
    Engineer
    Devalued?
    Engineer
