L.V switch gear
Hi,
I'm new to the IET so bear with me while i familaiarize myself. Does any one know of any Regs for a Low voltage section board 415volts, (Feeds 3 D.B's), a wood frame was constructed around it with plaster board walls, an acess door is there but is wood allowed in the construction. I have noticed the Regs state for a domestic dwelling but this is a Factory.
    Hello Philip,
    Not sure quite what your context is, but, from the way I read your post I see no issue, unless, the wood & plasterboard forms the enclosure over the live parts.
    If this "section board" is merely a large metal 3ph panel board then this secondary wood/plasterboard enclosure is merely cosmetic and forms no part of the electrical installation.
    You would get more help on the wiring regulations forum here:
    www.theiet.org/.../categories.cfm
    However, with just your existing description to go from it will be difficult to say definitively.
  • Thank you for the advice. As it's secondary to the 3phase
    enclosure which is metal there's no issue.  Appreciate your
    help.
    Philip
    Sent from my
    Samsung device
