Engineer Registration is coming to Victoria
The Victorian Government will soon be introducing a state-wide mandatory registration system for engineers.
It seems the details are still being drafted, and the scheme will be rolled out progressively.
The intention of this thread is to share information as it becomes available.
Documents:
Draft Bill (files will be uploaded and linked): www.legislation.vic.gov.au/.../a2ac889b33ea748aca2582480072eb59!OpenDocument
​Draft Bill: communities.theiet.org/.../15748
​Bill Explanatory Memo: communities.theiet.org/.../15749
Consultation Paper: www.dtf.vic.gov.au/.../Registration-of-Engineers-Stakeholder-Consultation-Paper.pdf
Engineers Australia Response: www.engineersaustralia.org.au/.../response_to_the_victorian_governments_consultation_paper_-_a_statutory_registration_scheme_for_victorian_engineers.pdf
News:
2018-03-07 AFR: www.afr.com/.../engineers-told-to-prove-qualifications-in-victoria-and-queensland-20180306-h0x2n2
2018-02-02 Herald Sun: www.heraldsun.com.au/.../6991e55dc485955961950aeed6b5d14c
2018-01-31 SAEA: www.saea.com.au/page-18489
2016-09-15 Professionals Australia: www.professionalsaustralia.org.au/.../
2014-12-01 Professionals Australia: www.professionalsaustralia.org.au/.../
Websites:
Engineers Australia: www.engineersaustralia.org.au/.../Victoria-Registration
Professionals Australia: www.professionalengineers.org.au/.../
    Thanks Evan for this,
    Just sharing a FAQ recently published by the VIC government regarding the Engineers Registration Bill 2018:
    https://www.dtf.vic.gov.au/sites/default/files/2018-05/FAQs%20for%20the%20engineers%20registration%20scheme.pdf
    Some interesting points from the document:
    From point 2.1: You will need to be registered if you provide 'professional engineering services' and these services fall within one of the five areas of engineering: civil, structural, fire safety, electrical or mechanical engineering.
    From point 2.2: 'Professional engineering services' is defined to mean an engineering service that requires, or that is based on, the application of engineering principles and data. to a design relating to engineering; or to a construction, production, operation or maintenance activity relating to engineering.
    From point 2.6: It is expected that the scheme will establish a requirement for 150 hours of CPD over three years.
    Best regards
    Sashi
  • Thanks EVan and Sasi, seems the rules are getting stronger, also pls check is there changes in MRA between and IET and Eng AUS, that help our CENGs to get involve easily wihtout having ENG AUS registration
    Jana
    'The scheme is expected to commence from mid-2019 using a staged registration process. It is envisaged the full scheme will be implemented by mid-2022. The detailed schedule for implementation will be included in the transitional regulations.'
