I have two supplies of different types coming into a distribution rack
(type 1 : 230V 1Ph+N max load 25A
type 2 : 110VAC reduced low voltage / centre tapped earth max load 55A )
id like if I can to isolate both using one 63A 4 pole isolator (coloured red yellow for emergency switching off). I can see from both the wiring regs and EN 60204 (this machine will require CE Marking) that every supply requires a means of isolation, but I can’t be sure if this means it’s own independent isolator. I kinda feel that I shouldn’t be mixing different supply types on the same isolator but then it would be actually useful in this particular installation. So is this bad practice?
