Roger Bryant:
If you were managing a bus company that has to make a profit to survive and supply a service to tempt people to use it rather than the alternatives how would your thinking go? Would you demand government (taxpayer's) subsidies? Would you, like the Germans, choose to use expensive electricity that frequently comes from dirty fossil fuel sources (brown coal) to support your virtue signaling?
Simon Barker:
Luciano Bacco:
Could this new British single-seater pod 'transform future mobility'?
https://www.imeche.org/news/news-article/could-this-new-british-single-seater-pod-'transform-future-mobility
So somebody has just produced a brand new vehicle that's just like a Renault Twizy, except with one less seat. The Twizy was first launched in 2012, and you can buy one from your local Renault dealer now.
mapj1:
Where does the electricity come from? If it is from burning fossil fuels I should probably stick with diesel buses
Not so simple. Firstly I may be trying to clean the air in the city, but less worried about the pollution from the power station.
Secondly, a diesel bus will not allow regenerative braking, and the engine runs even when you are stopped at the bus stop or in traffic (at least in older buses).
Consider this very modern 7900 electric volvo bus
an 8 hour day of perhaps 150-200km on a full charge.
or this
diesel figures, same manufacturer this sort of thing, perhaps 30 litres per 100km.
Looks like a winner - 30 litres for one hour only is 140kVA genset ( ish - link)
And electricity generation is a touch more efficient that a diesel genset in a proper power station.
And a lot better if like the UK we have some nuclear and some wind generation to throw in the mix.
So how far can we go on a 140 kVA battery?
usual caveats
so more like 100 to 200km in reality then.
Not clear that the electric option is worse, it may be better, even just as it is.
I'd be the first to agree there have been some noticable cock ups on early systems
example the Albuquerque Rapid Transit but I suggest that shows the technology is immature, not impossible
(battery temperature control was a large part of the failure of that pilot, and the longer range per day required compared to a typical
European city bus route.)
However, the reverse logistics of breaking down an electric battery are complex. At present it involves a specially trained technician wearing specific arc-flash-proof protective clothing and using insulated tooling. Risk assessment and method statements make the process as safe as it can be, but even with such protocols the danger of fire and electrocution is very real. Away from these obvious hazards, the handling of a battery that can weigh more than 600kg mass is awkward and sometimes easier said than done, especially when it is heavily damaged with componentry fusing together after a heat event."
