CreativeImpulse:
Hi Kenneth,
My concern would be a microwave would destroy the static electric deposits that filter the viral load in the ones I mentioned. I think you'd need specialist knowledge of the mechanisms used to evaluate that with microwaves.
Regarding the cleaning of other types of mask and other PPE, I see no reason why that shouldn't be appropriate. If it were microwave proof, i.e. not going to shrivel up like a crisp packet... and didn't contain metallic hinge pins. Then in theory it should kill anything biological in pretty short order. That might offer an option for more delicate materials, the static based masks are quite solidly constructed from my brief reading. That's half the problem, you have to penetrate the mask to sterilise it at depth. However, something lighter and less solid, with no EM involvement should be suitable for a microwave. The question will be whether the Covid is heated due to it's own molecular construct/carrier construct being excited by the RF, or whether it is heated by the material it's on being heated. If the material has to reach high temperatures, that could be a problem. If the Covid itself is heated by the RF, then you could blast it quite quickly with an industrial microwave such as you'd probably find in most hospital kitchens.
Of course, we are in a hospital... we have X-ray generators! Could these be (ab)used?
I think at this point we need the input of an RF expert with biological expert.
Cheers
Rob
Kenneth Hattersley:
Good point. Has this ref any validity? https://consteril.com/covid-19-pandemic-disinfection-and-sterilization-of-face-masks-for-viruses/.
This claims the simple "single use" "mask is not cleanable but that two more complex masks are.
Does anyone know if a microwave would directly neutralise COVID19 (or other ) viruses held in fabric / plastic mask filters?
The reference above mentions microwaves in terms of generating heat from a water bath, on which a mask is placed.
If there was a clinically approved method it could be useful.
Kenneth Hattersley:
The process should be safe for use by the operator because there is no handling of the sterilant, no toxic emissions, no residue to aerate, and low operating temperature means there is no danger of an accidental burn.
Susan Jones:
Concept - Portable respiratory support for emergency situations – Can SCUBA diving kit be easily adapted to provide it?
This is an idea we've been looking at with and Engineer / Scuba Diver. I appreciate that it may not be the first port of call but we see it is as a possible solution should care and mass recovery be moved to non-hospital situations, possibly without impacting existing supply chains.
Dear Colleague,
I am looking to see if you, or someone you know may have any ideas, feedback, or support on the attached idea for emergency respiratory support systems.
Covid-19 is causing unprecedented need for ventilation, even with increased manufacture will demand be met? If hospitals are at capacity improvised sites may need to be used, without plumbed oxygen. While we may not be at the point to need to think quite this laterally –we may yet reach it. There are 3 levels of respiratory support solution discussed, and while they may not currently be suitable for a hospital, they may be ideas which could prove useful in extreme or mass recovery situations (e.g. use of Stadiums to house patients). It should also not impact existing supply lines. If not for this virus - then the next where solutions that could call in civilian equipment & hold a library of designs for manufacture could prove vital.
Please take a moment to review the attached summary and supporting information, and respond with your thoughts. Please feel free to share it, as the aim here is to think of possible solutions, and work out if they could feasibly work, then develop them - which is why it’s being shared at such an early thought stage. In the hope that it may be useful to develop – or may trigger some ideas in others which it can help.
Thank you for your time, and please stay safe.
Kind Regards,
Susan Jones MEng CEng MIET MWES
