Tree vs Solar PV
There is some promise of Solar PV getting a another small leap in efficiency soon , the perskoyvite , has had the headlines recently but some talk of graphene based one has been around also , but no real life test results , but been doing a little comparison thinking to perhaps some eco thinking isnt as daft as it sounds.
If it takes 2 Hectares of land to have a solar PV array of peak 1MW output and estimated CO2 per kwh over a 25yr life span is 0.5g and if we have an average annual output of around 835,000 kwh for the 2 hecatre (will be more for high solar sites) then a CO2 cost of 417.7 kg a year (x25 year life span = 10,437.5 kg and perhaps if replaced 4 times in 100 yrs =41,750 kg)
Useful comparison point is 41,750kg of CO2 being produced in 100yrs by using them , but obviously quite good where they replace fossil fuel., they dont recycle , but bar the metals/doping pretty inert and probebly not too much of a problem , although sheer volume will be a problem , if we cant reccyle them.
If we plant the 2 hectares with trees for 100yrs and use the timber for building e.g houses lets see how this looks
A conifer forest will be absorbing around 0.8-2.5 tonnes of CO2 per hectare so 1.6-5 tonnes of CO2 per year for our 2 hectare plot and as we might harvest every 100yrs as useable timber somthing like 450,000kg will have been absorbed , and if we use to make houses , we also negate some of the CO2 of certain construction materials. Couldnt fing a kg wt for a single house using timber frame, so dont know how many houses it would make , also measuring timber is a bit of an art , fresh cut timber will lose about half its weight to become construction grade , and actual species has surprising differences in density.
If we think as biomass then before we started really mining coal , coppiced wood really was the energy mainstay for at least 1000yrs in the UK, charcoal enabling the bronze and iron smelting , and a 2 hectare coppice (if managed well and suitable species) could be absorbing 10-12 tonnes of CO2 per hectare , so 20-24 tonnes of CO2 per 2 hectares , over 100yrs is an astonishing 2,200,000kgs of CO2 absorbed.
Its true solar PV doesnt need water to grow and they are for now considered a good renewable , but the trees do go onto storing there captured CO2 much further as a building material , and of course when the woods life as a building material is done , we can burn it as biomass.
By comparison to , and to show just how important the tropical rainforests really are , a conifer forest that we typically see in N America and N Europe will absorb 0.8 to 2.5 tonnes of CO2 per hectare , the rainforests (as forest) absorbs 10 tonnes of CO2 per hectare per year ...
  • mmm apparently forest raking (as done as part of national life in FInland) is being looked at so we get a small biomass gain in the hectares 100yrs around 150,000kgs per hectare , just for comparative a 500MW biomass plant would be using around 300,000kgs of biomass per hour although new power stations are comming that are more efficient , and could make biomass more comonly used and sustainable , being sustainable is about the most important market limit that needs to be well managed , particulary as bio materials come along .Stopping forest fires would also be a good thing to do , dont forget that a forest fire is like 120,000kg (plus) of CO2 in one hour per hectare , as well as photsynthetic loss untils the trees/vegitation starts to regrow. The large forests really are our true long term friend  and partner in life on earth. (ok its the blue green algae and C4 pathways phtosynthetic plants , but the trees have the long time span and are the background)
    I am currently trying to work out how much oxygen our use of fossil fuels uses , somthing like 4bn barrels of oil are used every day , so that combustion uses oxygen , I am just wondering if there is some sort of Oxygen consumption problem no ones thought about , in that we are not replacing oxygen as fast as we should be for a fossil fuel economy ???
