Kelly Marie Angel
A similar thing to this incident happened near to me in the windy weather a few months ago. An11kV line insulator failed and H.V. tracked down a pole to the L.V. cables below blowing up many appliances and chargers in a nearby holiday chalet park.
Fallen power line leads to melted cable box, man shocked in shower - Bing video
  • Brings it home just how dangerous these incidents can be that was more than a bit of circulating current
  • Hi Zoomup‍
    Did you know that you don't have to use someone's name as the title of your topic in order to get their attention?
    You can just @ tag them and they'll get a notification to alert them ?
    Type the ‍ @ symbol and then their name (eg @Kelly Marie Angel‍ or @Lisa Miles‍ ) and select from the results.
    Hope that helps? ?
  • That is assuming they have the notifications turned on and check for them regularly.
    It is not a particularly easy system to use.
    M.
  • If you want to be notified when someone tags you in a conversation, visit your notification settings in your online community account and select the box that says 'Email me when someone mentions me'.
    Then if you are mentioned/tagged you're sent an email to let you know.
    That's correct isn't it Elizabeth Morgan‍ ? ?
  • Yep Lisa Miles‍ that is correct!? You should receive the notification on the hour.
