How will electric cars 'die'?
Has much research been carried out into what happens to electric cars as they age and how they eventually ‘die’?
There are several potential possibilities including:
1 The bodywork rusts away. Theoretically the same as for an ICE car, but will electric cars be on average more or less rust prone than ICE cars due to differences in the internal structure of the bodyshell?
2 Wear to suspension and steering components. Theoretically the same as for an ICE car. A common MOT failure that can be expensive to repair.
3 A catastrophic failure of the inverter and the cost of repair or replacement. Inverters are heavily stressed subassemblies that appear to have a finite life. Will power semiconductors and other components likely to break down with prolonged use be available and realistically replaceable, or will inverters be deliberately designed in order that failed components cannot be economically replaced?
4 Electronic systems failures where replacement is uneconomical. Theoretically similar for a modern ICE car.
5 The battery. High cost of replacement plus potential obsolescence (like try finding a replacement battery for a power tool from the 1990s) could sound the death knell of a 15 year old car that works just as good as the day it was new.
Will electric cars ever reach ‘banger’ status where it's possible to buy a >10 year old car for under £2000 and run it for 2 to 3 years? There are many people who subscribe to bangernomics, for one reason or another, but will it continue into the electric era or will a situation arise where it's impossible to buy a working electric car with a working battery for less than £10,000?
Will electric cars ever reach classic status where it's possible to buy a >25 year old car that can still be driven?
Could a situation arise where governments control the supply of batteries for electric cars and ‘tax’ them in a certain way to make up for the loss in fuel duty?
  • Rob Eagle:
    Furthermore cars less than 25 years old are no longer do-it-yourself jobs when it comes to maintenance and repair, the days of getting friendly with your local scrap dealer for parts is over.
    There are still bodywork and trim pieces that are just as easy for owners to replace on modern cars as they were on older cars.
    Electronic modules are usually easy for owners to replace if they fail, although some manufacturers have a bad habit of installing them in difficult to access locations.
    eBay has made buying replacement parts much easier than in the past.
  • Everything is so tightly packed into the engine bay of my car that I can't even get my hand in! Compare that to my 1980 Mk IV Cortina I had back in the 80s, I could almost stand in the engine bay with the engine, everything was easily accessible thereby DIYable.
  • Rob Eagle:
    Fair point. The engine compartment of modern cars can be difficult to work in because everything is tightly packed. What I find frustrating is how much stuff needs to be removed (and subsequently replaced) in order to replace parts that wear - such as drive belts, water pumps, coolant hoses etc. It's possible for owners to replace an alternator on many cars from the 1980s in under 30 minutes. On modern cars it often takes the best part of a day to accomplish.
    Thankfully, electric cars have much less in the way of mechanical parts and hoses than ICE cars. Far fewer items that can go wrong or are consumable parts. In theory, a comparison of electric trains vs diesel trains offers some insight into reliability of electric cars and which parts are most likely to fail or require periodic replacement.
  • Are you telling me that electric cars don't even have an alternator?
    Whatever next, cor blimey. ???
  • Gideon:
    I have an electric toy car with a second DC motor used in reverse as a generator to recharge the battery whilst it is running.
